Engine I'd and sterngland repack
John-m
Inlägg av John-m »
My fjord 27 is out of the water now for the winter and i have a few jobs to do.
It has a straight six deisel in it I thinks it properly original and iam looking for info on it as what it is and where to get things like the raw water impeller for it. Also the sterngland is leaking a bit to much so want to service that to.
Hopefully someone can help me
Thanks in advance
John
John-m
Re: Engine I'd and sterngland repack
Inlägg av John-m »
Min fjord 27 befinner sig i vatten nu för vintern och jag har några jobb att göra. Det har en rak sex deisel i det jag anser det riktigt originella och iam söker info om det som det är och var att få saker som obehandlat vatten impeller. Även sterngland läcker en bit till så vill service att. Hoppas någon kan hjälpa mig Tack på förhand John
Found a translator so trying again
Hi John,
What brand/manufacture of the engine are you referring to ?
John-m
Inlägg av John-m »
Thanks for the reply, pretty sure it's the standard straight six desiel but can't see any markings on it.
Hi again,
I am afraid that there is no such thing a standard engine. Different manufactures have marine converted there engines with different components. To be able to find the right parts it is essential to know the engine brand. Do you have a picture of the engine?
Most Fjord boats have however Volvo engines.
John-m
Inlägg av John-m »
Sorry no picture but it's a straight six volvo penta deisel. The stern gland is a bit of bronze tube with a grease nipple jubilee cliped to the stern tube. Can't find anything similar on the net.
