Hello as per title how much does a single deisel engined fjord 27 weigh. Just wondering if I could put it on a trailer rather than craning in and out.
Cheers john
How much does a fjord 27 weigh
Re: How much does a fjord 27 weigh
I think the stated dry-weight is 2.4 metric tons, then add engine with drive, what´s in your diesel and watertanks, batteries, stuff like bowthruster, windlass etc. And maybe a little extra interior carpentry...you easily exceed 3 tons. The estimated weight of my Selcruiser (loaded with the above mentioned) is 3.4 t. I have never thought about trailing her in and out of the water, sounds a bit risky...
Regards,
Kim
Regards,
Kim
Hi,
The weight according to sales brochure is approximately 2300 kg but could be more dependent on the engine installed.
Doesn't that make her about 5 old tons? I always took her as being round about that. I would have thought that it would make it illegal to pull unless you had something pretty hefty. At least a Discovery.
having said that, you mind the pictures on this link to YBW forums quite interesting
http://www.ybw.com/forums/showthread.ph ... selcruiser
